oh ya and after having the car run for like 10-30 seconds it dosent do it anymore
when i start the car and its cold outside and i turn the wheel its shaky and feels unstable... thats without having the car move.
any ideas on why that is?
When I first bought my car it also had some wierd vibrations mostly in the seat but steering wheel a little too. I replaced motor mounts and transmission mounts. That cured it.
Flush the power steering fluid and be sure the belt is tight
Your power steering has to warm up
edit: I was always under the assumption it puts a lot of strain on the power steering pump when you turn the wheel without at least slightly rolling.
1990 Islandgrun 535iM Sedan
3k oil changes | Euro lights + trim | Eibach/Bilstein | EAT Chip
if your fluid is CHF11s, its contaminated.
if its ATF, get a better ATF like Redline D4 that operates at very low temps.
oh... i had refilled the liquid recently, maybe it was CHF11, and i contaminated it?
i used D4
D4 and 11s are not compatible, if they mixed bad things are happening
flushing it tomorow...Originally Posted by BillionPa
what kinda bad things though?
it creates a wax solid particulate that clogs the oil passages
