Hi,
I replaced the front brake rotors and pads on my 1991 535i (after 60k miles!) and noticed something interesting:
The rotors have seven holes, five for wheel lugs and two more. One lines up with the rotor mounting bolt hole; what is the other hole for?
Now here's the funny thing; on my car, the left front hub had a hole that lined up with the other hole on the rotor, not the one it should be. The problem is that this other hole is oversize and just fits the head of the bolt. This means that anti-rotation is ensured but the rotor flops around if the wheel is removed.
I know that this car was involved in some kind of "incident" before I bought it as the left front has been repaired. It appears that the hub was replaced too, but with what part? Did later cars have this different hole pattern? Is this a non-OEM hub?
Finally, is there a bolt I can use that would correctly hold the rotor (hole in rotor is counterbored so it suggests it's possible).
Adnan
