Results 1 to 4 of 4
Thread: Touring question
    Minneapolis, MN
    Default Touring question
    Since I purchased my 1992 touring in November, I have been puzzled by one thing. When I am driving the car it sounds like the hatch or a rear window is open, but when I check all are properly closed. Does anyone else notice this? I have replaced the rubber gasket that goes around the rear hatch opening but I still hear the noise. Nothing major, but if possible, I would like to find a solution.
    1992 BMW 525iT (sold)
    1998 V70R
    Nov 2006
    Quote Originally Posted by brick8
    Do you have a sunroof? If so check that it’s properly sealing. Being off a bit creates a whooshing noise at speed. Otherwise are all the window and door moldings in proper shape? No rips or tears?
    1992 525i Touring M50 5spd Manual 230k+ miles - SOLD:-(
    Minneapolis, MN
    I think the sunroof is ok. Went through a carwash this week (foolish considering the temp here) and no leaks. One of the door window moldings is slightly torn. I ordered a replacement from dealer using the part # from realoem but it is the wrong part. Will keep you all posted.
    1998 V70R
    Connecticut
    The 95 Touring we just bought has quite abit of wind noise because the inside door seals have shrunk and left gaps at the rear upper corner of each door opening. I bought a new one for the drivers door & will use pieces of the old one I remove to fix the others. Sectioned in under the sill cover the repair should be unnoticible.
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
  1. e34 Touring rack question
    By motuman in forum 5 Series BMW
    Last Post: 09-14-2009, 09:25 PM
  2. Another Touring-specific question!
    Last Post: 04-07-2009, 11:30 PM
  3. Touring question
    By gtopaul in forum 5 Series BMW
    Last Post: 11-05-2006, 08:30 AM
  4. Suspension Question for Touring Gurus
    By KennyG in forum 5 Series BMW
    Last Post: 01-19-2006, 07:06 AM
  5. e34 touring glass question
    By GM525 in forum 5 Series BMW
    Last Post: 03-20-2005, 12:53 PM
