Originally Posted by scott 4991
Look more like M20 bleeder.
M30 has the expansion tank on the firewall
I have looked at my expansion tank and do not see the referenced bleed 'screw' - does anyone have a picture of this screw. I'd like to see where it's located.
Radiator mounted expansion tank:
1. Loosen the bleed screw on top of radiator expansion tank and let the coolant flow out as you pour it in the reservoir. Tighten the screw when the flow out is free of air bubbles.
Separate expansion tank:
1. Loosen the bleed screw on top of thermostat housing and let the coolant flow out as you pour it in the reservoir. Tighten the screw when the flow out is smooth and free of air bubbles.
*** I do see a bleeder screw coming of my radiator hose..
sc
scott 4991
535i, 172K miles
Thanks guys, I know where the thermostat bleed screw is, but the one on the expansion tank I can't find. I do not think there is one, but I may be wrong, this is why I ask the question.
scott 4991
535i, 172K miles
There isnt one.Originally Posted by scott 4991
Since your car does not have a radiator mounted expansion tank the post you originally quoted does not apply to your car. The only coolant bleed screw on a 535i is on the thermostat housing.Originally Posted by scott 4991
90 535im
02 R1100S, 87 R100S
76 R90/S,73 R75/5
Alfa Romeos- 65 Giulia Spider Veloce
& 66 Duetto 1600 Spider
Thanks, just what I needed to know.
sc
scott 4991
535i, 172K miles
