Nice one nick, keep us updated.
Hey everybody,
I thought I'd try one of these out as I have far too much work at present: no time for a weekend or 3 to install the MegaSquirt quite yet.
Just got it in the post. My neighbour recently bought an M20 powered E30 which needed a few things fixing so we decided to buy our new MAF upgrades together. Miller charged us no extra for the postage... and have been very conscientious throughout.
For those not so in the know here; A MAF does not bring a heap of perfromance, but it does give better efficiency and if your AFM is worn out, its a great thing to do. Saves you in Gas, makes the engine run better and adds at least 3HP... LOL
Actually it comes with a performance chip so with the benefits of that one gets significantly more over a bog-stock Normally Aspirated engine.
As you can see from the pics, it is surprisingly well made. The custom alluminium body is milled beautifully and its really solid. I was worried it would be plastic but am now relieved. I tried to take some decent macro shots so you could see the level of finish.
If it works, it'll be well worth it...
They will both go on this weekend. I'll be comparing mine to how she ran on both the stock chip and the performance chips I have borrowed from Big Kriss, after running each for some months. The AFMs on both cars are pretty good (after an internal inspection, output measurement and flap position) but they are as old as the cars...
Have tried Mark's infamous EAT chip and the Australian PowerChip, both of which are excellent chips. I'll let y'all know how she goes...
Heh, with pics of speedos off the clock and power drifts? Maybe I should get it professionally road-tested on a French motorway NickOriginally Posted by BigKriss
Installation
Dead easy, make sure you have 3mm heat shrink tube and a foot of 15mm wire protector on hand, a soldering iron and wire clippers. Big philips screewdriver, 6 and 10mm sockets, an extension bar and ratchet.
I managed to mis-connect it with a poor splice on the positive feed, so was surprised after buttoning the ECU back up and heading out for a drive that she just paused when I gave her some throttle. Not a splutter, just a 'kind of nothing' (after all this anticipation it was something of a let-down!!).
So we went carefully round the block and back into the shed. After finding the 12V feed was not working, I fixed it and started her again. Previously (without the MAF powered up), the idle was as smooth as a kitten's fur... but with the MAF now powered I watched the tacho showing the ECU hunting a little during initial warmup (pulsing the revs around +/- 50rpm) before settling after about 20secs later on a calmer and slightly lower 750 odd rpm... much better!
Buttometer readings (after first short drive)
Off the mark
- Definately smoother throttle response
- Same power
Mid range
- Noticably more power (maybe as much as 10%)
- certainly more responsive to change I can only compare it to how a lightened flywheel can liven up an M30
Upper rev range
- Flicks the tail when turning sharply with much more ease
- Definately faster up hills (completely different car under Wide Open Throttle) once you open it up
Economy
(The main reason I did this)
- NFI yet
Important Note:
Traditionally these cars perform better after a CPU reset (but use more fuel and output worse emissions). I will klnow more after running a few tanks of fuel through it and the CPU has learnt about its new inputs.
It is a completetly different car.
Even the brakes feel better... (really weird)!
This is, without a doubt the best budget mod you can do to the M30. If you have a 535 or 735 powered car, either get one of these or install a MegaSquirt. The AFM will limit everything you do to the car and makes it drive like a pig in comparison.
I don't know how much difference a new AFM would make to other people's cars, but my old one was in very good shape (had been rebuilt) and was physically perfect... the electronics were fine. I expect the problem was the spring had lost its tension.
The difference made is like night and day. My guesstimate of a 10% power increase seems pretty conservative now... Nick
I'll post some pics and chronicle the effect it has on the M20 when we get around to it this week...
Glad to hear the maf kit is working out for you. Does the maf sensor need 12v switched, or can it work off the 4.7v~ish from the afm harness? Are you using the ground from the afm harness? This can be important, as motronic sensors seem to like to be grounded with the dme, especially the innovate wideband o2 stuff.
You should realize quite a bump in midrange torque with the maf. The modern perf maf I had in my 535 dyno'd with a healthy improvement about the midrange.
erased due to slander
Here's Jeffrey's dyno run with the same maf kit, from Bruno. Unfortunately, the dyno wasn't calibrated for metric mechanic horsepower.
This post is intended as added disclosure to the topic at hand.
It's entirely likely the speed-up is due to the lost weight of the AFM!Originally Posted by genphreak
Martin - that sheet is nice... sure Jeff doesn't mind you showing his dirty laundry?
Robin
72 Chevy K10
01 E39 M5
