Results 1 to 2 of 2
Thread: Can you 5 series drivers help me with steering problem
    Jan 2007
    Vermont
    Default Can you 5 series drivers help me with steering problem
    I was hoping you 5 series drivers might help me with a steering problem Im having with my 98 E36.
    Any ideas would be greatly appreciated!
    See info here http://www.bimmer.info/forum/showthread.php?t=30202
    Thanks
    Tony
    98 328is/sport, 5spd, M3 duals 98k miles
    Mar 2004
    Since it's intermittent and goes away when warm, I suspect the relief valve in the pump is sticking. You can tee a gage (2000 psi?) in pump discharge line to check or install a used pump. I've experienced this in my '83 533i w/o R&P steering in cold weather but it only lasted a second or two after starting.
    Paul Shovestul
    Quote Originally Posted by tonyvt328is
    Thanks
    Tony
  1. Safety Recall: E34 5 Series Touring - Check the Steering Lock
    Last Post: 04-10-2008, 07:10 AM
  2. Drivers side Window problem again
    By Al Gray in forum 5 Series BMW
    Last Post: 04-17-2006, 04:23 PM
  3. Drivers side Window: I found the problem
    Last Post: 04-09-2006, 05:25 PM
  4. 3 Series Rims on an E34 Problem
    By The Melmaan in forum 5 Series BMW
    Last Post: 10-10-2004, 10:55 PM
  5. problem with the drivers door lock
    By micjordan in forum 5 Series BMW
    Last Post: 08-28-2004, 10:51 PM
