Results 1 to 4 of 4
Thread: Broken rear shock?
    Bay Area, CA
    Default Broken rear shock?
    Hey guys,
    I had a tinny clunk coming from the driver side rear of the ol' e34 and it sounded as if it were coming from the strut's top nut. After looking at it, the rear shock mounts were cracked so I replaced them and the sound is still there (although quieter).
    Could the shock be so bad that it's causing this problem? It is on the original 137,000 mile shocks! I know it needs new ones, and new ones are on their way, but could this even be the cause of the problem?
    I took video of it for those who want to see what I'm talking about.
    http://video.google.com/videoplay?do...33621416509559
    Any help is appreciated. Thanks!
    looks like the shock is sticking inside. Shouldnt take too long before it busts up the new shock mounts.
    Maryland
    swap them.. they're inexpensive and easy to replace... there's one 21mm nut holding the shock to the lower arm (trailing arm?) 94 ft lbs on the torque... easy job
    Bay Area, CA
    Yeah, I've done the job a few times (swapping suspensions, etc) but just wanted to know if it was the shocks before I started the job or if there were other things I should fix / replace at the same time.
    Thanks for the info, guys
  1. Rear shock height - 89 535
    By pomko in forum 5 Series BMW
    Last Post: 07-25-2007, 08:51 AM
  2. rear shock
    By 318speed in forum 3 Series BMW
    Last Post: 07-10-2006, 12:12 AM
  3. Help!!!! I Can Not Get Rear Shock Off!!!!!
    By Badkrma in forum 5 Series BMW
    Last Post: 03-12-2005, 06:36 PM
  4. Rear shock mounts
    By Black 535i in forum 5 Series BMW
    Last Post: 12-27-2004, 10:56 AM
  5. Rear Shock Replacement
    By jbw535i in forum 5 Series BMW
    Last Post: 03-30-2004, 03:48 PM
