Originally Posted by
Martin in Bellevue
Think the ATF moved enough sludge to block the oil pump pickup? It might be time to drop the pan for a look. Avoid the cork pan gasket if doing this; napa has the preferred rubber gasket.
In my '90 535ia there was not much of any sludge in there before I did the ATF trick, per inspection and biopsy done through the oil level sensor hole. Dark stains to be sure, but no thick or gooey crud whatever before I ATFed the engine. Just to be safe, I'll probably do this again.
The ATF pretty much removed the oil stains from the underside of the valve cover, making it look like new. I only ran 1 qt of ATF + topoff of new 10W40 in the engine with a new filter for a short time, under light load, then drained and replaced with 20W50 and yet another new filter. Methinks the occasional flickering low oil pressure light is primarily a function of low idle speed (~600-700rpm) on coasting to a stop after the engine is warmed up. This never happens when the engine is not at full temp (oil still thick) or when not coasting to stop. Could be, the brand new oil pressure sender is a wee bit off. Blip of the accelerator pedal stops the flicker, but I worry anyhow.
BTW, is there any cheap and commonly available (i.e., NAPA, etc.) oil filter out there, so I don't need to mail order from BMA, etc,?
Dash01
'90 535ia 272K miles
