Thread: replacing valve cover gaskets
    NEPA
    Default replacing valve cover gaskets
    hey guys. to the poeple who have done this on the M60. would it be wise to get the upper inner gasket that goes around the coil packs or no?
    USA
    yes, and the throttle body gasket too, and all new bolts that you will probably strip.
    Wichita, KS
    Default Definitely do the inners
    Mine were seeping when I got to them - lots of oil around the plugs. Make sure the valve covers are real clean in the grooves for the new gaskets too. Being aluminum heads, it is worth it to crack the plugs loose, check, and retorque with a very little fresh antiseize. I never touched any of the induction gaskets (throttle body, or others as mentioned in another post). Unless they're leaking - leave em be.
    May the Schwarz be with you...
    NEPA
    im waiting for that job when the weather gets warmer. but yea n intake re-seal is on the to-do list. my car idles like crap in this cold weather.
    those come with the valve cover gaskets. Make sure you replace both intake end seals while you do the intake gaskets.
    Quote Originally Posted by markus
    Aug 2005
    Do 2.0L and 2.5L M50 engines share the same valve cover gaskets? Realoem gives the same part number.
    2.0L http://realoem.com/bmw/showparts.do?...83&hg=11&fg=15
    2.5L http://realoem.com/bmw/showparts.do?...83&hg=11&fg=15
    I am asking because a CRP gasket on bmaparts seems to have a different part number:
    http://www.bmaparts.com/epcvsoapimc....entid=bmaparts
    CRP is a good brand right if valve cover gaskets, right?
    VIN: GG45422
  1. Finished changing both valve cover gaskets,
    By Bo525i in forum 5 Series BMW
    Last Post: 12-10-2009, 08:26 PM
  2. M60 valve cover gaskets this weekend
    Last Post: 03-24-2007, 06:22 AM
  3. Valve Cover Gaskets
    By hinchcliffe in forum 5 Series BMW
    Last Post: 01-01-2007, 04:19 PM
  4. Valve cover gaskets - replace or not?
    By pingu in forum 5 Series BMW
    Last Post: 05-27-2006, 10:24 PM
