Results 1 to 2 of 2
Thread: OT: Tools
    Atlanta
    Default OT: Tools
    Drill Press: A tall upright machine useful for suddenly snatching flat bar stock out of your hands, striking you in the chest
    and flinging your beer across the room, splattering it against that
    freshly painted part on the workbench.
    Wire Wheel: Cleans paint off bolts and throws them under the
    workbench at the speed of light. Also removes fingerprints and guitar
    calluses in the time it takes to say "ouch!"
    Electric Hand Drill: Normally used for spinning pop rivets in
    their holes until you die of old age.
    Pliers: Used to round off bolt heads. May also be used to create
    blood blisters.
    Hacksaw: One of a family of cutting tools built on the Ouija
    Board principle. It transforms human energy into a crooked,
    unpredictable motion and the more you attempt to influence its direction
    the more dismal your failure becomes.
    Vice Grips: Generaly used after pliers to further round off a
    bolt. If nothing else is available, they can also be used to transfer
    intense welding heat to the palm of your hand.
    Oxy-acetylene Torch: Used almost exclusively for lighting
    various flamable objects in your shop on fire. Also handy for setting
    fire to the grease around that wheel bearing you were trying to remove
    by heating the hub.
    Whitworth Sockets: Once used for working on older British cars
    and motorcycles. Now mostly are hammered over bolts previously rounded
    by vice grips.
    Hydraulic Floor Jack: Used for lowering an automobile to the
    ground after installing new brake shoes, trapping the handle firmly
    under the bumper. May also be used to lower vehicle onto the plastic
    pail you drained the engine oil into, immediatly prior to moving the
    vehicle and spilling oil all over your concrete driveway.
    Two by Four: An eight-foot long bar made of wood used for
    levering the vehicle upward off the hydraulic floor jack handle.
    Tweezers: A tool for removing 2X4 splinters or wire wheel wires
    from your fingers.
    E-Z Out Bolt and Stud Extractor: A tool 10 times harder than any
    known drill bit that snaps off in bolt holes. Works well in inexpensive
    or easy to replace parts but using this tool in expensive parts will
    cause almost certain failure.
    Two-Ton Engine Hoist: Used for testing the tensile strength of
    electrical wires, hoses etc that you forgot to disconnect.
    Craftsman 1/2 X 16 inch Screwdriver. A large prybar that
    inexplicably has an accurately machined flat tip at the opposite end to
    the handle.
    Aviation Metal Snips: See "Hacksaw."
    Trouble Light: A very appropriately named tool. Its two main
    purposes are to shine an intense light directly into your eyes instead
    of onto the part you are trying to illuminate and also to consume 40
    watt light bulbs at the same rate as a 105 mm Howitzer consumes shells.
    Sometimes called a drop light for reasons obvious to anybody who has
    used one.
    Philips Screwdriver: Normally used to stab the silver vacuum
    seals under the srew off lids of oil cans but can also be used, as the
    name implies, to strip out the heads of phillips screws.
    Pry Bar: A tool often used to crumple the metal surrounding a
    clip or bracket you needed to remove in order to replace that 50 cent
    part.
    Hose Cutter: Used to make hoses too short.
    Hammer: Originally used as a weapon of war, but nowadays used as
    a device used to locate the most expensive parts adjacent to the part
    you are trying to hit.
    Utility Knife: Used to open boxes and slice through the contents
    of packages delivered to your front door. Works particularly well on
    items such as seats, CD's, liquids in plastic bottles, collector
    magazines etc. Especially useful for slicing through work clothes, but
    only when you are in them.
    Dammit Tool: Any tool that gets thrown across the garage as you
    yell "Dammit!" It is also the next tool that you will need.
    Expletive: A soothing balm, or mechanics lube, usualy applied
    verbally and in hindsight, which somehow eases the pain and embarrasment
    of our lack of foresight.
    Aug 2006
    Durham, NC
    I know all about the Dammit Tool ... LOL...
  1. I am looking for these Tools
    By begeta50 in forum 5 Series BMW
    Last Post: 11-09-2006, 07:18 AM
  2. I Need Name Of Tools
    Last Post: 10-22-2006, 01:58 AM
  3. OT, tools, Winfred don't know if you have
    Last Post: 06-29-2006, 12:27 PM
  4. Metrinch Tools
    By JMI in forum 5 Series BMW
    Last Post: 03-23-2006, 12:35 AM
  5. what tools do i need to...........
    Last Post: 08-16-2004, 02:53 PM
