Results 1 to 4 of 4
Thread: Transmission fluid colour
    Norcross, GA
    Default Transmission fluid colour
    Hi All,
    Recently I changed the Tranny filter and replaced just the drained fluid with Valvoline Dexron III Maxlife. It took about 5 1/2 qts.
    The old fluid was little brown in colour but did not have any smell. In fact it was completely odur less. I have attached the blot test image. What do you think? Is my transmission safe? Or I am looking at a major Tranny problem in the recent future?
    Tranny is ZF5HP18 aka a5s310z.
    Arun
    530i / Nikasil M60 3 Ltr Motor / ZF5HP18 (A5S 310Z) Tranny / Prod: March 95 / Fully stock / 95K miles
    that looks great! Its when its real brown and smelly that you will have a future problem. Why so much fluid? Did it drain all night or something? Mine took 3.5 quarts almost 4 total.
    Norcross, GA
    Thats a good news for me.
    Initially it took about 3.5 qts. Then I let the car idle till the temp was around 30 C. I moved the shifter thru all selections. Then it took another 1 1/2 qts.
    I think mine had quite less fluid to begin with. There was a little seepage around the gaskets area. Now I have changed the filter with O-ring, crush washers and gasket.
    I used Valvoline Maxlife Dex III to refill. This thing had a real stink. Is all Dex III like that?
    Arun
    Honolulu
    Default Change the fliuid one more
    time with your next oil change.
    This will help freshen it up, since not all the fluid was changed.
  1. What Transmission Fluid should I use?
    By vping in forum 5 Series BMW
    Last Post: 04-09-2009, 01:02 AM
  2. transmission fluid
    By jrindin in forum 5 Series BMW
    Last Post: 02-09-2007, 09:52 AM
  3. Transmission fluid pump
    Last Post: 08-02-2006, 11:10 AM
  4. Transmission Fluid; Dexron II or III?
    Last Post: 09-10-2005, 11:26 PM
  5. Transmission Fluid Dip Stick??
    By shield17 in forum 5 Series BMW
    Last Post: 03-12-2004, 06:28 AM
