Hi Guys,
Just came across this forum. looks like a good crowd of people.
I've got an 1989 535i Auto Right hand drive, and I'm having some problems with the locking mechanisim on the drives door. The drivers door won't lock.
If i put the key into the drivers door and turn to lock it, the other doors locks go down, but then they all come back up again, if i turn the key a second time, then the other doors lock, but the drivers door still remains unlocked. Its the same when unlocking the doors but in reverse. So basically I have to turn key twice to get the car unlocked or locked.
And only way to deal with drivers door is to set the alarm, and even then I don't know if its on or not. Sometimes I open the driver door without unlocking the alarm doesn't go off. Other times it does. but that's a separate issue.
Another note is that the drivers door button won't go down at all. Seems like its stuck.
Sooo....today I pulled the door panel off and got into the door, but I don't know how to get the lock out. The actuator is working fine. I un-attached it and tested it just by pulling and pushing, and the other doors work as normal. i.e. I dont have to do it twice to get them to lock or unlock.
Next I unscrewed the latch part. (the bit that latches onto the door when you close it) and held that loose to see if thats was jammed and not letting the driver door lock and tested the locks, problem still exists. (I hope that paragraph makes sense)
I wanted to fulled remove the latch part, but it was still connected to the lock barrel part and I couldn't work out how to get it off. the connecting rod looked like it was attached with a nut, and the other end I couldn't see well enough.
So now I'm not sure which part/s is/are faulty and whether I can fix it/them myself or best to just get a mechanic to do it.
Any help would be much appreciated.
Thanks in advance,
Ben
