Results 1 to 8 of 8
Thread: What is this part? Check valve?
    Dec 2006
    San Jose, CA
    Default What is this part? Check valve?
    Not sure what this is. I think it's some kind check valve, PVC? Should it be cleaned? How do I know if it's bad / working properly? I see a vacuum lead here, closed off. Any one know what the vacuum should read at this location so I can check mine against a know good value?
    sc
    scott 4991
    535i, 172K miles
    Honolulu
    Default I think this is the booster
    line for the brakes.
    the brake booster uses vacuum to power the power grakes
    That is in fact a check valve. It allows for the vacuum from the intake manifold to operate the brake booster. It's purpose is to prevent vacuum fluctuation in the manifold due to you applying the brakes. The extra nipple is a known vacuum leak source and thus shouldn't be disturbed. HTH
    Default Uh, not quite, its purpose is to
    allow vacum to be stored in the booster so you have some assist for a stop or two if the engine stalls while driving, If the check valve is working correctly you can push the brake pedal down a couple of times with the engine off and you can feel the boost go away as you use up the stored vacum. The pedal gets harder and higher.
    Quote Originally Posted by Rus
    I stand corrected
    Dec 2006
    San Jose, CA
    Thanks guys.
    sc
    scott 4991
    535i, 172K miles
    Feb 2005
    kIWI LAND(New Zealand)
    Thanks I always wondered what that thing was
    89 535 272,000km auto Euro
    Quote Originally Posted by scott 4991
    sc
    PCV, methinks. Those factory clamps suck, and allow vacuum leaks. Better to replace and/or wrap some electrical tape over this and other potential leaks.
  1. Replies: 4
    Last Post: 12-19-2010, 02:53 PM
  2. Water Valve Bracket Part no
    By MBXB in forum 5 Series BMW
    Last Post: 06-25-2008, 04:21 AM
  3. Part no. for non-return valve?
    By E34-520iSE in forum 5 Series BMW
    Last Post: 04-24-2006, 09:28 AM
  4. Fuel pump check valve part number
    Last Post: 03-23-2006, 10:19 PM
  5. part nos. check please
    Last Post: 09-19-2005, 03:51 AM
