Originally Posted by
ryan roopnarine
OK, will start off by following up from my post yesterday. my car was severely bucking, running rough, hard to get over 40 mph. i found that the FPR was broken internally, and changed it out. slight improvement, but the problem still persists. i listen to each coilpack, and note that no 1 is clicking loudly enough to be mistaken for a tappet. i take out no 1, and note that the boot now has an almost 1 1/2 inch tear along the bottom. i replace it with a spare that i have on hand. my idle improves a decent bit. at this point, i say, f' it, and start pulling out coilpack connectors (the ones at the bottom, not the connector at the plug itself) and looking for which ones can be disconnected without changing the idle. i suspect that two are doing this, and swap out what few parts/boots i have...the idle is a little better, but one can still see a little bit of white in the exhaust.
by now, i've taken the cover off of the fuel injector connector "box" and started probing. all 6 injectors come back with running voltages of .26-.40, pulsing--as much as one can observe pulsing on a multimeter. the spec--by bentley is .3-1.0v, but i chock this up to my multimeter being $4 from harbor freight on sale. i check the ohmage of each injector, each comes back at precisely 16.8 ohms, within spec. i check the resistances of each of the coils, all within spec--.8ohms--by bentley. the CPS checks at about 596 ohms, within spec. the car "feels" like a classic, but very mild, disconnected plug wire, or mixed up plug wire misfire. admittedly, the car has been running a little rich for a while now, but it never did anything like produce smoke at acceleration. is it possible that leaking injectors could be doing this? when i took the rail out to get to the FPR, i didn't notice any of them dribbling, though i was too much of a dumb @ss to think to try them out at key-on pressure while the rail was out of the intake manifold. any, ANY suggestions?
