To turn the engine I use thinned 1-1/4" wrench on water pump while applying thumb pressure on fan belt. Removing the plugs makes it easier…but not essential.
To find TDC I use the firing order 153624, recognizing that when one cylinder is at TDC on compression stroke, there is another cylinder at TDC on exhaust stroke.
When cylinder 1 is at TDC (compression), valves on cylinder 6 are "rocking" (TDC exhaust). That is turning engine one direction opens intake valve, turning the other direction opens the exhaust.
When cylinder 1 is at TDC, valves on cylinder 6 are "rocking" 153624
When cylinder 5 is at TDC, valves on cylinder 2 are "rocking" 153624
When cylinder 3 is at TDC, valves on cylinder 4 are "rocking" 153624
When cylinder 6 is at TDC, valves on cylinder 1 are "rocking" 153624
When cylinder 2 is at TDC, valves on cylinder 5 are "rocking" 153624
When cylinder 4 is at TDC, valves on cylinder 3 are "rocking" 153624
See the pattern?
With this method you can start anywhere by looking for the cylinder whose valves are closest to “rocking”
Paul Shovestul
Originally Posted by
Bart
Anybody use the clean-wood-dowel-rod-in-the-spark-plug-hole trick for determining top dead center for each cylinder? (Works great on BMW motorcycles, as long as cleanliness is strictly observed.)
How about bumping the starter motor with the ignition key to turn the engine?
How about using the 32mm fan/water pump nut and belt tension to turn the engine to the next setting?
Any thoughts on insight into these or similar tips & tricks will be much appreciated.
