Results 1 to 10 of 27
Thread: Zerex G48 coolant - where to buy?
    Benneton (United Colors of)
    aha!
    there's the rub!
    somebody pinpointed the difference. if they made it nitrate free, that's as big a difference to me as the g05 having phosphates as pH controls (which it doesn't, of course). those pH differences are BIG stuff, only through good engineering are they able to keep the pH's that close on the g48 without the use of the common buffers like PO4s or NO3s. i have prestone all-makes in there right now, but once i reattach the heater core to my coolant system and replace all of my hoses, maybe take the rad out and reverse flush- i'll try to go blue again. the fords in my fleet that spring leaks will still get g-05, its still better than green. curious thing about g-05. around 1999/1998 or so, when our taurus was made, the antifreeze in it was an orange color, but was not dexcool--the dealership told us this, and not to put dexcool in it. the instruction manual said not to use green coolant in our car, and that you should only use gold or orange colored coolant, whatever color the car was equipped with. come to find out later that the orange was the first attempt at g-05--after the dealership replaced a transmission under warranty and flushed the car with green coolant
    original poster: if you can't find bmw coolant at a price you are willing to pay, and you only need a partial refill, just get some prestone all-makes antifreeze (IIRC, bill was the first one to suggest doing this) and use it until your next flush, then use das blau if you want. don't bother mixing the g-05, too much work for too little, since you'd have to go out of your way anyways.
  1. Zerex G05 - 50/50??
    By scott 4991 in forum 5 Series BMW
    Last Post: 02-03-2007, 08:26 PM
  2. Check coolant message, how do you "top off" coolant
    By gmannino in forum 5 Series BMW
    Last Post: 01-06-2007, 01:13 AM
  3. Zerex G05 + residual Blue = ?
    By tim in forum 5 Series BMW
    Last Post: 09-13-2006, 04:52 PM
  4. Replies: 0
    Last Post: 10-07-2004, 11:01 AM
  5. Replies: 9
    Last Post: 02-18-2004, 11:05 AM
