Results 1 to 8 of 8
Thread: Will i pass emissions?
    Sep 2006
    Newnan
    Default Will i pass emissions?
    I have to get it done this week, no way around it and my car still has that idling issue.
    It will run smooth unless i let it sit at 500rpm for more than 10 seconds, then it will throw a code and idle like crap. I believe whats happening is that a bad sensor is causing me to run rich and its causing me to miss on a cylider. Thats what i believe it is, since i only have this problem at low RPM's.
    what ive been doing for the last month is pushing in the accelerator(in Neutral) until i sit at 1200rpm, this prevents the bad idle at a stop.
    what should i do when i pull up to get it tested? let it sit or do the 1200rpm trick? Do you think it will pass?
    1995 BMW 530ia/3.15lsd/M Parallels/Eibach/Bilstien/Magnaflow
    Aug 2006
    Boulder, CO, USA
    I don't think any country will pass you if you have a check engine light on. If you are in the USA, do the stomp test, otherwise get the code read.
    Weymouth, Mass
    You probably wont pass, sounds like a vacuum leak. Do you have a mighty vac or a vaccum gauge so you can see what you have at idle?
    Zack
    Weymouth, Mass
    -1989 Dinan 535i Intercooled Turbo
    -1997 Mercedes Benz E300 Diesel (Daily)
    Sep 2006
    Newnan
    Changed: PCV, intake manifold gaskets, like all 4 vacum lines, spark plugs(twice), o2 sensors, valve cover gaskets(were for sure leaking) Checked fuel injectors
    havent checked: Coils, temp sensor, crank sensor, and i believe there is one other sensor i havent mentioned that could be a culprit.
    Most likely air flow meter.
    Where I am if you have a fault code in the computer you fail. You clear the codes and not let the idle condition occur that sets the code if you want to try and fool them. Chances are though that the repair will pay for itself with fuel economy.
    Dec 2006
    Long Island
    if you take it in for an inspection they will hose you big time.
    even if you reset the engine light you have to drive the car for a certain time/distance to complete x# of drive cycles.
    my buddy couldn't wait and brought his neon in for an inspection, they changed both 02 sensors and the cat because he didnt complete the drive time like I told him to.
    Sep 2006
    Newnan
    Out of cash this month so thats why im trying to wing it. I figured if you had a code stored it wouldnt pass, wasnt sure if it was the same for obd1. i will use the stomp test to reset the code and tryto keep it from showing, wish me luck
  1. How to pass the emissions test
    By Snork in forum 5 Series BMW
    Last Post: 10-29-2007, 12:34 PM
  2. Emissions
    Last Post: 08-26-2005, 08:28 PM
  3. emissions...HELP!
    By Mike M in forum 5 Series BMW
    Last Post: 09-21-2004, 06:44 PM
  4. Any wagers if my modded E34 will pass emissions?
    Last Post: 09-15-2004, 07:27 PM
  5. Emissions Problem
    Last Post: 05-25-2004, 02:41 PM
