I have to get it done this week, no way around it and my car still has that idling issue.
It will run smooth unless i let it sit at 500rpm for more than 10 seconds, then it will throw a code and idle like crap. I believe whats happening is that a bad sensor is causing me to run rich and its causing me to miss on a cylider. Thats what i believe it is, since i only have this problem at low RPM's.
what ive been doing for the last month is pushing in the accelerator(in Neutral) until i sit at 1200rpm, this prevents the bad idle at a stop.
what should i do when i pull up to get it tested? let it sit or do the 1200rpm trick? Do you think it will pass?
