Results 1 to 10 of 13
Thread: so whats better metal end oil plastic filters?
    NEPA
    Default so whats better metal end oil plastic filters?
    just oredered another liter or ate super blue and an oil filter. i decided to go with a metal ended one because i can always pull out the plastic support correct? its a mahle one if that matters. i have no idea which one the car has in it now.
    Honolulu
    Default The last filter for my M50
    was some kind of molded plastic ended one from Mann.
    it worked the same, but I don't have that plastic do-dad adapter.
    Plastic... the redesigned it because of loss of oil pressure upon startup. That insert keeps oil in the filter rather than to let them drain out. I still have one metal filter that I bought by mistake... u want it?
    Hockinson, Washington
    You forgot wooden.
    Jan 2007
    LA
    They are interchangeable?
    USA
    no. the metal ones WILL NOT fit in the oil filter container designed for plastic filters.
    Jan 2007
    LA
    Will a plastic fit on a orig metal?
    USA
    no, the entire canister was redesigned.
    its just an insert that can be removed for the metal end filters.
    Quote Originally Posted by BillionPa
    Connecticut
    So when did this all take place? What should I expect to find in our new 95 525iT? I was planning on dumping the oil this weekend & have a Napa filter with metal ends. Should I wait until the filters I ordered from BMA arrive & just return this one?
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
  1. Kidney grill - metal or plastic?
    Last Post: 08-09-2008, 07:21 PM
  2. Whats this!?! A plastic impellor?
    By Hallmark in forum 5 Series BMW
    Last Post: 07-15-2005, 08:45 PM
  3. Replies: 3
    Last Post: 04-05-2005, 11:53 AM
  4. whats this thing and whats the effect of a broken one??
    Last Post: 05-23-2004, 06:54 AM
  5. whats this thing and whats the effect of a broken one??
    Last Post: 05-23-2004, 02:26 AM
