Results 1 to 10 of 14
Thread: Help shop needs help 328is -check engine light
    Jan 2007
    Vermont
    Default Help shop needs help 328is -check engine light
    So this shop replaced my driveshaft assembly-ok. Broke exhaust bolts ect,,-ok fixed. Used torch on manifold and welded mid section pipes back on.
    Now check engine light on. Says all 4 02 sensors bad? Now way.
    What could this be? Please help!!!!
    tony
    May 2005
    Jet City
    I'm wondering if the O2 sensors were contaminated by the vapor by-product of the welding, (inside the pipes).
    Spasso
    530iT, 525 5-speed , 328is.
    Jan 2007
    Vermont
    Could they be cleaned??
    Anyone know anything about this???
    PLEASE HELP!!!!
    baton rouge, loserana
    take it for a good rip down the road then reset the light and see if it comes back after another rip, the back sensors hardly ever die and the fronts are not going to go at once, the 96 and up cars have problems with the crankcase vapor recovery system where it leaks vacuum and screws up the mixture which usually sets front 02 codes
    they may of started it with the exhaust off the car and that set the codes
    Jan 2007
    Vermont
    Thanks I will try that.
    Do you think putting a torch on the manifolds could have cooked one or both of the front ones? If one shorted would they all show bad?
    Thanks for taking the time to reply!
    Tony
    unless they directed the flame right on the sensor and left it there (i test sensors with a propane torch and clean them with a mapp torch) it should be fine, it can deal with heat after all it doesn't start working till the tip reaches 600 degrees, i've yet to see one trigger codes for all my best guess is they started with them all unplugged
    Jan 2007
    Vermont
    THEY CANT CLEAR THE CODES. ANYONE HAVE ANY IDEA???
    IM LOOSING MY MIND
    at this point it's down to diagnostic skills, if they all crapped at the same time look for whats common for all of the sensors like the 02 sensor heater relay or if theres a fuse for the heater circuit
    Jan 2007
    Vermont
    It goes back in today for a new check. the shop has purchaced the BMW chip for their scan tool..
    BTW..Just found out my 328is has M3 exhast....
    Runs ok with check engine light on but bad gas mileage...
    Jan 2007
    Vermont
    Quote Originally Posted by tonyvt328is
    They cant fix it. Installed 1 new 02 sensor still shows both front bad. They told me they dont know what to do. I hate to go to the dealer.
    Any ideas??? Anyone?
  1. check engine light-???
    Last Post: 01-31-2009, 01:00 PM
  2. Check Engine light won't come on
    By BennyM in forum 5 Series BMW
    Last Post: 12-21-2008, 11:41 PM
  3. check engine light flickers with engine miss
    By cobb535 in forum 5 Series BMW
    Last Post: 05-25-2007, 11:21 AM
  4. Check engine light on....?
    By Ken from Guam in forum 5 Series BMW
    Last Post: 10-20-2004, 08:23 PM
  5. Check Engine Light
    Last Post: 07-09-2004, 02:55 AM
