Results 1 to 7 of 7
Thread: Q to E36 electric cracks
    Default Q to E36 electric cracks
    Car spec.:
    Daten für die Fahrgestell-Nr./VIN AM90320
    type code/Typschlüssel: CB62
    Katalysator: mit (with cat)
    Lenkung: rechts/ right hand drive
    Getriebe: automatisch/ automatic transmission
    Baureihe: E36/3 series
    Ausführung: Europa/ Europe version
    model/Bezeichnung: 320i
    Motor/engine type: M52
    Karosserie/chassis type: Limousine
    Produktionjahr/production year: 04/1995
    Werk/manufactured in Munich: München
    Problem:
    hi there, i am having problems with my e36 320iSE, 1995(m), it has the m50 vanos engine. when trying to start my car it just turns over, there was no noise coming from the petrol pump as it didnt sound as if it were priming. ran a live feed to it and it worked. i then checked the connections to the sender unit and the voltage was as it should be, i then checked the fuses, it wasnt blown so i took it out and checked the voltage for the connection. this is where it gets strange, there is no voltage coming to the fuse. we have checked various other connection but to no avail, like i say the car will turn over continuously without flooding. please help as i am stumped.
    thanks
    chris
    any recommendations?
    fuel pump bridging? which pins?
    wiring diagrams I have are these
    http://www.gbnetwork.co.uk/bmw/downloadetm.html
    baton rouge, loserana
    does it spark if not theres other problems, they need to see what all works to diagnose it, like do the injectors have their constant 12v with the key on or does it spark, bridge #30 to #87 at the fuel pump relay to power the pump, if #30 is hot, which should be powered by the main relay
    Default winfred, his answer
    THE INJECTORS DONT WORK, THE WHOLE CAR SEEMS DEAD, IT WILL JUST TURN OVER, NO FUEL PUMP, NO INJECTORS. NOTHING AT ALL
    Your answer?
    kingsbridge, devon, uk
    bit of a long shot but i had a simalar problem with a nissan a few years back, i managed to trace it right back to the ecu, i had the same symtoms as you , fuel pump and injectors not working, i got another ecu (a second hand one) and it was good as gold after that
    main relay or ref sensor would be my first checks, with a remote possiblity of a shut down by a malfunctioning ews if equiped
    Your answer?
    Aug 2006
    Kansas City, MO
    Try swapping the relay out. You can manually jump the prongs on the relay as well.. you could manually jump it with a wire and see if its starts then.
  1. E32 electric + non electric rear seat removal
    Last Post: 10-02-2014, 03:21 AM
  2. M50 owners:Check your air intake elbows for cracks
    Last Post: 05-22-2008, 10:36 AM
  3. ever check rims for cracks?
    By Elekta in forum 5 Series BMW
    Last Post: 01-15-2008, 03:09 AM
  4. Electric Fan
    By GoldenOne in forum 5 Series BMW
    Last Post: 10-01-2006, 09:33 AM
  5. Electric Fan
    By charlotte37 in forum 3 Series BMW
    Last Post: 12-20-2005, 08:08 AM
