Results 1 to 2 of 2
Thread: Economy / Shift Indicator on 1995 BMW 525i Auto
    Mar 2004
    Default Economy / Shift Indicator on 1995 BMW 525i Auto
    Long story short,
    After many repeated component changes, the instrument display that shows the current trans mode and gear selected (under check control) now occasionally fades away to a blank display. Turning the ignition off and restarting always brings this display back to normal. Any thoughts? This occurs with the engine running or not.
    I should also mention that I get phantom TRANS PROG faults, but these are not recorded in any control unit. Have had the car at the dealer and used the Diagnostics - even with the TRANS PROG fault present on the CCM it does NOT show on the Transmission computer, the ECU or the instrument cluster.
    Components changed or swapped - Transmission control unit, Check Control Module, Instrument board ($800), transmission switches cleaned and verified proper (using diagnostics). The Engine Control Unit has NOT been swapped - yet. Throttle position sensor passes all tests as well. Most grounds have been checked and look good (tightened). The 50A fuse near the battery is fine. The alternator is fine - voltage good with and without load.
    I am at wits end....
    Scott
    Mar 2004
    [QUOTE=Scott C]Long story short,
    Since the BMW diagnostic tester actually induces the reporting of a trans prog fault (or can), I wonder if anybody has had a problem with the CAN communications network used internally by all of the black boxes for diagnostics? That seems to be the next area to look.
    Scott
  1. How I fix a loose shift lever- auto 95 525i?
    Last Post: 10-24-2011, 11:45 AM
  2. E34 1995 525i Auto Won't Start
    By Don_B in forum 5 Series BMW
    Last Post: 01-12-2009, 05:23 PM
  3. Coolant problem 1995 525i Auto
    By John24 in forum 5 Series BMW
    Last Post: 06-01-2004, 05:55 AM
