Results 1 to 10 of 14
Thread: 94 540i - new owner - transmission & drivetrain
    Jan 2007
    US - Iowa
    Default 94 540i - new owner - transmission & drivetrain
    I am the new owner of a 1994 540i. This is my first BMW.
    From all I read about Bimmers, they are known for responsiveness and
    silky-smooth transmissions. Mine seems neither terribly responsive nor
    silky-smooth.
    1) Shudder when accelerating. I know this can be related to driveshaft.
    My mechanic confirms this, although it's not the "typical" remedies
    that are recommended elsewhere in this newsgroup. Those fixes have
    already been done. He recommends changing out the whole driveshaft.
    Thoughts?
    2) Tranny seems to not downshift as it should for first half-mile or so
    of driving. RPMs very high, like it's not shifting into higher than
    3rd. Then a noticeable "settling" of the transmission as it does what
    it's supposed to do.
    3) Generally, gear shifting does not seem smooth as silk at all.
    I know this is hard to comment on in this kind of forum, but just
    wondering what your thoughts are. I am aware of the Nikasil issue with
    the cylinders, but not sure that any of these things have anything to
    do with that.
    Basically, it comes down to this: I bought the car to have a FUN car to
    drive, right now it's not, and I don't know if it's my car in
    particular or if my expectations are wrong/too high.
    Most of this has been discussed in depth.
    1) Drive shafts do go bad, it's a in the seat of the pants vibration. Shuddering can describe pretty much anything -- need more info.
    2) It doesn't seem to be shifting past third when cold because it isn't. The transmission electronics are programmed to hold gears when cold to speed up the warming process. Once the car is hot, it shifts normally.
    3) What's the mileage? Car could be getting ready for a valve body job.
    It's probably the car. People typically sell used BMWs because they're a headache and they cost a lot to repair if you don't do your own work. If the car doesn't have much service history and is around ~ 130k, get ready for a cycle of replacing wear parts. After a while, it'll calm down and not require much maintenance.
    May 2005
    central coast nsw au
    The 540 is a geat fkn car so your expections are right to be high. as kal said shuddering can be a number of things.
    1. How are the tranny and engine mounts? first place to look
    2. uni joint, how is it? CV ?
    3. centre bearing and flex disc( guibo as some call it)? whats the story there
    4. dog bones and rubbers etc
    5. as kal asked whats the mileage???
    6. Drive shaft change overs are expensive as they come as a complete unit, this is rarely an answer to anything.
    7. have someone experienced in BMW trannys assess the tranny fluid and change or adjust accordingly.
    8. we need to know more about the car to give any relevant help. eg: milage, history, condition, country located within etc etc. as there nuances from counrty to country with these cars.
    ps. have you had a look under the car yourself and are you mechanically minded?
    welcome and hope we can help and of course pics pics pics
    Jan 2007
    US - Iowa
    Quote Originally Posted by mattyb
    Not very mechanically inclined, but learning more everyday. Centre bearing and flex disc have recently been replaced, I know. Tranny fluid is a little dirty but not terrible, according to mechanic.
    More about car: USA, 86000 miles, one owner, well taken care of (good parts & work, according to mechanic), don't know service history. Overall looks to be in great condition.
    May 2005
    need to assess cv and rubbers. if its been looked after and has relativley low miles then driveshaft should be OK. when it comes to nuts and bolts remember its just a big mechano set and you dont have be a genuis to work on most of the stuff. the only way to learn is to get your hands dirty and have some fun with a little pain along the way, youll save thousands. there is os much information on this site and heaprs of great folks who have done it all before so dont be scared of having a go at something simple to start.
    Hows wheel alignment and balance?
    Jan 2007
    US - Iowa
    Quote Originally Posted by Kalevera
    Thanks for the response. Didn't know that about the transmission electronics. Mileage is 86,000. Mechanic says it's been very well maintained - quality work and parts done, and it's in great shape for its age.
    USA
    if you let the car warm up from cold cold for exactly 180s, you will not experience the shift delays.
    if you have the money, let a trans specialist drop the tranny, inspect the clutch packs and valve body, replace as necessary with new filter and fluid.
    follow mattyb's list for diagnosis.
    remember, your car is 13 years old, and if driven hard, that is a VERY long time. it will need maintenance in many if not all of its key mechanical and electrical systems to drive like it did 10 years ago, and depending on how much cash you throw at it, drive better than it did new.
    May 2005
    yes, good and very valid point about warming up there. it can never hurt to let it idle for a couple of minutes. btw fred nikasil would have nothing to do with issues you have at the moment. its only a valid point if u happen to live in some parts of the US with crap fuel local. The guys in the US will be able to help you there more than I cause Im in OZ and we never had nikasil issues here touch wood or laminate.
    The Netherlands, around Amterdam (as every place is)
    Default Idle as short as possible
    ... it can never hurt to let it idle for a couple of minutes
    I'm sorry mate I have to disagree with you here ... the best thing for any car is to start it up and drive away gently ASAP. Oil pressure is not that great idling, especially when cold. And don't rev beyond 3K until oil has warmed up (depends on storage and outside temp).
    You're a victim of your brain
    NEPA
    bmw even recomends driving as soon as you start
  1. Possibly looking for a 540I transmission
    By ArtemLepilov in forum 5 Series BMW
    Last Post: 04-16-2006, 02:57 PM
  2. newbie e34 540i owner questions.
    By kurt-o in forum 5 Series BMW
    Last Post: 04-13-2005, 09:28 AM
  3. E34 540i Transmission Fuggered?
    By Jamiediddy in forum 5 Series BMW
    Last Post: 04-04-2005, 04:06 AM
  4. New e34 540i owner
    By digitaldragon03 in forum 5 Series BMW
    Last Post: 02-03-2005, 12:37 AM
  5. 94 540i transmission flush problems
    By Phil M in forum 5 Series BMW
    Last Post: 06-05-2004, 09:17 AM
