Originally Posted by
blkspruce
How am I to tell if the core is bad?
I'd fill the radiator with water as much as possible, then start motor and set the heater to full heat with fan on. Raise the RPM's and contine to add water till it's topped up with water.
Bleed it, and put the Rad. cap back on.
Wait for Temp. and pressure to bulid up. And you should be able to locate obvious leaks.
If you saw a puddle under the car, it should show up again if you do the above.
1991 525i M50 5 Sp.
N.California
