Oy Vey,I'm too old for this
I got the door handle surrounds on OK.Then while i was in a fix it mode i thought I'd check that nut at the base of the steering shaft.My car has some paneling covering that area,keeps everything looking neat and sophisticated down there but to get that off there are not only several small screws holding it up but you have to remove the front dash panel.OK , that's not so bad but there wasn't enough light to finish the job so before i could get to that steering shaft nut i decided I'd better get the screws back in place or I'd be doing it tomorrow only the weather report is for Schloony Winter Misery to finally find us.Man the positions you have to assume to get under there and work on these areas is hell on my body.I am dreading the heater core job even more now. My memory of which screw goes where is not going to suffice for the number of pieces involved in that job.. detailed charts and pictures will abound for sure.
1995 540i Manual build 1/95
