Cure time in cold garage
If your garage is cold, I would suggest some sort of heat to speed up cure time. If you do use a space heater, I would put out a long thick bead of the urethane material and cut off a piece every 12 hours or so. That way you will have some idea how fast it cures.
After 36 hours and no heat, there is still a lot of material not cured in my samples. Only the outside 1/4 inch is cured even with temperature of 40-55 degrees and is rainy. IMO that means the material deep inside the bushing is still uncured! Because of this situation, I do not plan to move my car until at least another 24 hours, which is 72 hours more or less. Even so, I may fire up a small ceramic heater and see what happens.
