Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Clutch replacement and cost projections
    PA
    Quote Originally Posted by Jehu
    I just had my six speed clutch and flywheel done.I took it to the shop on a Thursday morning and i got it back Friday evening.Cost $1,900.00. I live at a Condominium Complex so have no garage or tools ,certainly not anything to drop the tranny so it was never even a remote consideration that i could do any of it myself. The shop said everything looked to be original so i anticipate this to last me longer than the car will run.
    What did the shop do in regard to the flywheel, do you know? Most shops insist they be replaced - my clutch is grabbing my DIY cleaned flywheel VERY nicely.
    Default Clutch change
    The clutch release bearing failed on my 1991 535i toward the end of last year. 140K and original clutch. Sachs kit from BMA-$275, labor at local tranny shop (excellent shop)-$300. I had them replace the oxygen sensor while the exhaust was out. Picked up the car the next day. The owner wanted to buy the car right there! Nothing else needed. Now I could have gone nuts and replaced a lot of parts while it was on the lift but they told me nothing really required immediate attention.
    Paul
    Connecticut
    $300 for labor is an extremely good price. Much less then I would charge after doing it myself. $1900 seems extremely high unless the job on an 8 cyl. is much more difficult??
    90 535im
    02 R1100S, 87 R100S
    76 R90/S,73 R75/5
    Alfa Romeos- 65 Giulia Spider Veloce
    & 66 Duetto 1600 Spider
    Los Angeles
    I paid $650 a few years ago for a new clutch and guibo.
    db
    93 525i
    167k
    dave b
    93 525i
    156k +
    Long Island, NY
    The reason why the V8s cost so much for a clutch job is that if it needs a new flywheel, and it frequently does, that alone lists for about $800. I don't know how true it is, but it seems that the dual mass flywheels in the V8s aren't supposed to be resurfaced.
    I was quoted anywhere between $900-$1300 for the clutch job alone, but after the new flywheel it ended up around $1900.
    '94 540I 6spd/205000 miles
    PA
    No DMF is supposed to be resurface but I believe that to be a little heavy on the ******** seasoning.
  1. OT: cost of 540i-6 clutch job
    Last Post: 05-07-2007, 07:49 AM
  2. How much should a clutch job cost on a 540?
    By bbig119 in forum 5 Series BMW
    Last Post: 10-20-2006, 11:02 AM
  3. How much should a clutch job cost on a 540?
    By bbig119 in forum Engine & Drivetrain
    Last Post: 10-20-2006, 10:55 AM
