Results 1 to 9 of 9
Thread: HID Low Beam Failure Fix
    Default HID Low Beam Failure Fix
    quote
    HIDs operate on 35W whereas halogens operate on 55W. In some vehicles, the difference in current will trigger a "low beam failure indicator." As a result, your HID Conversion kit will not function properly. This product will fix this issue so that you can install your HID conversion kit with no problems.
    unquote
    http://www.xenondepot.com/product.php?product_id=126
    Apr 2004
    trinidad, in the caribbean
    why would it not work properly???
    i have an HID kit in my car, i also get the 'dip beam' error code but the hid's work fine.
    what makes the hid not work properly?
    anyone have any experience with this?
    [IMG]
    "this product will get hot" LOL... it is just a resistor in there. What a joke! When you have older HID ballast, it will show low beam error, but the newer one should not show those error as they internally have been wired to show continuity. Older ballast will not show continuity and this tells the computer bulb is broken.
    T·O·R·O·N·T·O
    It's not because of the wattage difference. Tiger explained it right.
    USA
    my fix is to wire in a small bulb, like halfway sized between an 1157 and a dome light, directly parallel to each low beam bulb. no relays to mess with, and its cheap as ****!
    Vancouver, WA
    Very cool. I'm sure it could be made cheaper, but for guys that don't have the time/knowledge to put it together, this is a terrific product. Price is suprisingly low I have to admit.
    -Seth- Vancouver, WA
    535im is gone...
    PA
    Guys I have 6 of these resistors they are often used for using low impedance injectors on a high impedance setup - they are roughly $5 ea
    Vancouver, WA
    Source?
    535im is gone...
    PA
    Quote Originally Posted by s_ribbens
    Source?
    www.digikey.com
  1. Replies: 3
    Last Post: 06-29-2008, 10:03 AM
  2. Low Beam +
    By ljbarnhill in forum 5 Series BMW
    Last Post: 09-21-2006, 03:59 AM
  3. Low-beam failure fix?
    By MTechnik540i in forum 5 Series BMW
    Last Post: 03-29-2006, 02:30 AM
  4. OBC Failure
    By e65rt in forum 7 Series BMW
    Last Post: 09-11-2005, 07:54 AM
  5. Dip beam failure
    By Jeff in forum 5 Series BMW
    Last Post: 10-16-2004, 10:32 PM
