Results 1 to 8 of 8
Thread: Fog/water droplets on inside of windshield.
    Aug 2005
    West Portland, OR
    Default Fog/water droplets on inside of windshield.
    What the heck?
    It was like my car was fairly foggy, even after hours of being cold.
    Yet, the kind of nasty thing about it, there were fairly good sized distinguishable DROPLETS forming, as if my interior was just saturated.
    The windshield was the only thing like this, the other windows were only slightly foggy.
    It was slightly slick, so do you think my coolant is leaking in someplace in my vents, and when my ac/heat turns off it just evaps onto my window?
    I've never seen it so nasty before. Also, sometimes my car smells a tad bit moldy, but it goes away after a minute of ac/heat. I think there could be some kind of buildup/leak going into my vents up front under the window...
    EuroLux:. Private Detail
    Derbyshire, UK
    It might have popped the heater core. Check your coolant level. If it stays steady, check for interior leaks where rainwater might be coming in.
    1997 535i V8
    Aug 2005
    West Portland, OR
    blech, I am always getting a coolant level warning.
    Guess it's time for a new heater core X-O
    Damn damn damn!!!
    May 2006
    NH
    Join the club....mine's not so bad i can't live with it,i think.Who knows,maybe even the little bit that i smell is enough to cause some kind of harm.i am hoping it will be bearable till it gets warmer around here to do that ten hour job some warm spring day.
    1995 540i Manual build 1/95
    Wellington,New Zealand
    do you have your vent system set ot recirculate or fresh air.....you need to run it on fresh air regularly
    Gone but not forgotten
    Hockinson, Washington
    If you need some help replacing it, i might be able to.
    Honolulu
    Default I only get this
    when:
    car is parked on a deserted road and.....
    both seats are reclined
    both occupants are naked
    and
    the car is rocking
    Aug 2005
    West Portland, OR
    Quote Originally Posted by Paul in NZ
    It's always on fresh air :-/
  1. Exhaust spitting out tiny droplets...
    Last Post: 01-24-2007, 10:06 PM
  2. Replies: 22
    Last Post: 08-12-2006, 11:52 AM
  3. Replies: 3
    Last Post: 08-08-2006, 11:02 PM
  4. Water inside the door
    By Jay 535i in forum 5 Series BMW
    Last Post: 04-19-2006, 06:21 PM
  5. Help with water leak inside car please!
    By Steve525 in forum 5 Series BMW
    Last Post: 11-06-2005, 10:38 AM
