it seems most aftermarket manufactures "O" rings are smaller and seep air into the pickup tube. Get something OEM.
My transmission is a bit whiney, I wasn't sure if this was typical or if I need to change my transmission fluid?
Not really loud, and seems smooth (shifts great every time) but I didn't know if it was normal...
Just curious... Input?
EuroLux:. Private Detail
eh?
So the PO put aftermarket parts in my transmission?
...Awesome.
Time to review the maintinence records again.
*Kills Paul Allen... with an axe...to the face."
Dude you need an E31 with no records at all, everythings gonna be good, a little here and there.
Originally Posted by CharlesAFerg
wear, usually a slight whine going slow, does not get louder with speed.
leaky filter O ring, as Jeff pointed out a bad O ring or wrong filter (short pick up tube) will cause air the enter the system. More common on the V8 trans.
or just a clogged up filter making it cavitate
What should I use to record audio in my car?
Should I just make a video with an expensive camera w/audio and post it?
they are full of whines
uh, stop...the plastic on the couch is sticking to my back
oh! you're hurting me
oye, that's not a kosher postion
aaahh, if you do that, I'll never kiss you on the lips again!
Fran Drescher......
Change the fluid - Royal Purple synchro max i guess thats ok for autos its an ATF. It takes like 30 mins.
Valvoline max life dextron III, change it a couple of times with your oil changes and it will live on.
