Results 1 to 5 of 5
Thread: 520i M50 engine misfiring under load.
    Jan 2007
    Default 520i M50 engine misfiring under load.
    Had the problems with the fuel pump, this seems all ok now but the car has a misfire, it seems worse under load and at lower revs, above 3.5k it seems to improve. not sure if the misfire was there before the fuel pump problems as got the car with the fault, any ideas?
    I suppose could start with the basics like new plugs etc.
    PA
    Check for oil in the spark plug holes - leaky VC gasket
    Jan 2007
    will do,
    Yep, misfire under load is often weak ignition.
    probably a failing coil, easyer to diagnose with a automatic where you can power brake it while popping coil plugs off to see which one is crapping out
  1. 520i E34 - Check Engine light?
    By andylarox in forum 5 Series BMW
    Last Post: 09-20-2008, 05:30 PM
  2. Need Piston for 1989 E34 M20 520i Engine
    By julielewis in forum 5 Series BMW
    Last Post: 01-09-2007, 10:51 PM
  3. removing sump on 520i m20 engine
    By af1 in forum 5 Series BMW
    Last Post: 11-28-2006, 02:28 AM
  4. Replies: 14
    Last Post: 10-10-2006, 08:47 AM
  5. E34 520i 24V cold engine knocking sound
    Last Post: 03-09-2004, 10:20 AM
