Did anyone try that? Any clereance problems? With what tyre size?
Jan
Jan
Won't work. The offset is wrong and the wheel hits the shock towers. I know this only because I accidentally tried to put the rear wheel on the front of my M5 when I got them. 9" front is way too wide anyways--you wouldn't be able to steer the car it would have so much understeer.
So you tried M5 wheel with ET22? Do you remember how far it was wrong? I mean it was touching the strut "just" or it was even not close to succesfull fiting?Originally Posted by VentoGT
What you mean? Wide front wheels are making the car more oversteer (opposite to common understeer problem in E34 with wide rear tyres).Originally Posted by VentoGT
Jan
Front Style 37 (Parallel) for E34 are 8x18 and they are not rub. It's the matter of offset.Originally Posted by filip00
Jan
18x8.5 seems to be the biggest you can put up front comfortably. with 9" you'd need to run spacers.
Vento- you have 18x8 and 18x9, right? that would mean you have something like 265/35/18 tires, which definitely wont work for the front.
perhaps with a smaller tire and a spacer.
Originally Posted by Alexlind123
Yea.. I have 8x 18s with the correct offset and my back ones still rub a little. I am going back to the stock springs in the rear just to try and get them to work.
A Young Man with a Plan![]()
ericbendler@yahoo.com
Something must be wrong in your car: the body, wheel offset or tyre size. BMW allowed 9x18' ET22 with 245/40R18 on the back:Originally Posted by ericbendler
http://www.realoem.com/bmw/showparts...90&hg=36&fg=15
Jan
