Changing the fluid at such a high mileage is a bad idea. It will cause what was holding it together to come apart and cause it to fail. It's a commonly discussed topic.
Joe Here in Orlando
1994 BMW 530I
I took my car to Fields BMW to have my transmission service last week. A young twenty something guy changed by transmission fluid and he said that the fluid was burnt. Well anyway I wanted the fluid and the filter changed. He only changed the fluid. He also didn't tighten the bolt tightly and now my transmission fluid is leaking a little.
One of the service advisors told me that I should not have the filter changed. The transmission is still shifting harshly. Should I have the filter changed or not? He said if I have the filter the transmission would not work anymore (Go FIGURE)
IS THIS THE END OF THE ROAD FOR MY 530i?
The transmission was slipping so I took the car to the dealer and they suggest I change the fluid, So what do I do now that the gasket is leaking? IS THIS CAR TOASTED?
Originally Posted by bimmerd00d
Its transmission might be, but thats an excuse to do a 5-speed swap, not an end for the car.Originally Posted by Green Bimmer
Thanks for the advise, but I don't have that kind of money right now. Maybe I will put the car up for sale and hoping I can get some money out of it.
Originally Posted by Alexlind123
trans shops and dealers are crapshots. you need to change the filter ! they want you back for the 8000.00 change. be subjective here and search till you cant... its in here bro, I dont want to retype what i did hundreds of times.
indeed, get that filter changed NOW. and replace the fluid again when you do it.
then a week later change the fluid again. if you see crap in the old fluid, change it next week too, and keep doing that till its clean!
So you are saying that it is OK to change the Trans filter? I mean I am at a point that I have no choice but to try changing the filter and the heck with Fields BMW mechanics. I was charged $130 for the young apprentice to change trans fluid, what a waste. From the advise I am getting I wonder has any of you guys actually changed transmission fluid and filter in 1994 530i? I noticed in the Bentley manual there are instructions showing how to change the transmission fluid and filter. I am not a serious mechanic, I am taking the car to a shop that I trust. I mean one way or another I am going to find out whether transmission will fail. Right now God only knows
Originally Posted by 632 Regal
WOW! I really like your answer. You talk like you have done this job or has it done before. I like it when people give good sound advise (from experience). So again you are saying to change the fuild and filter?
Originally Posted by BillionPa
since the fluid has already been flushed you really dont have much choice, the damage has been done. cluch disk material is not magnetic, so the magnets in the pan will not pick that crap up, you must rely on the filter. changing the filter will increase fluid flow which will remove more deposits from inside the transmission.
depending on how much, they can either escape the filter and get in the valve bodies, or be caught and only cause a problem when too much of them escape. thats why you need to keep changing the fluid till its clean.
if you do the work yourself its not that expensive, you just have to be very patient and work with the car on a level surface to ensure the proper amount of fluid is loaded.
