Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Thinking About Buying a 95 525iT
    Connecticut
    Default Thinking About Buying a 95 525iT
    What kind of mileage can I expect out of the auto trans? Known issues? Is the rear suspension a problem area? Whats involved in converting to standard rear shocks? Were any of these imported with 5 speeds?
    Nov 2006
    Mid-Atlantic, USA
    Quote Originally Posted by John B.
    Depends, on how it's been driven and maintained. Many have gone well over 100k and others see failure at 60k. Maintenance history seems to be critical.
    Known issues?
    Water pumps, radiators, suspension bushings, shocks, control arms, tie-rods, motor/transmission mounts; all are normal maintenance and the majority needed around 100k.
    Someone else will have to tell you about shocks, there's no pump or plumbing, just unique shocks. Front suspension is more problematic than rear I'd say.
    No, but many have converted them to 5-speeds. Selling a good auto-trans while it's still working can pay for a 5-speed conversion.
    Connecticut
    Quote Originally Posted by BMWCCA1
    The car currently has 136k on it so its already over 100k. Its a 2 owner well maintained vehicle but from what you are saying the auto tranny is not known for a long life??
    Nov 2004
    Winston-Salem, NC
    Mine's at almost 190k on the original fluid, I think (can't find evidence in the service records and since it was dealer maintained for 12 years I bet they didn't change it). It runs well and I have no problems what so ever. I'm sure it isn't as crisp as a new tranny, but it runs better and smoother than transmissions on some of the new cars I've test driven.
    My approach is to wait for the tranny to grenade and then switch it over. Just start saving.
    -ashley
    Paper Gaskets Suck!
    Minneapolis, MN
    My 1992 525it with 160k miles has the original auto transmission. Shifts fine but the manual and sports settings are problematic. Fine if you stick to ED.
    1992 BMW 525iT (sold)
    1998 V70R
    Connecticut
    Quote Originally Posted by brick8
    Problematic in what way? Is this an external problem with the electronics or something inside the tranny?
    Minneapolis, MN
    I think it is an electronic problem and I haven't had time to delve into it. Basically, what happens is if you try driving on the highway in manual or sport mode the car goes into limp home mode when you hit 70mph. You can then reset it by turning the car off and pushing the reset button on the right side of the instrument cluster. The car then drives fine. Never have a problem at any speed with the car in auto mode (ED).
    1998 V70R
    Jun 2005
    Pacific Beach, CA
    I bought mine a little over a year ago and the PO paid some $2500 for a rebuilt tranny @ 112K. From what I've read, tranny life is about 100-125K under normal circumstances.
    If you're getting a touring, check out the dual sunroofs and make sure that's happening (expensive fix). Also, the rear hatch can, over time, pinch and sever the wiring harness back there, giving you eletrical fits.
    That said, E34 Tourings are an excellent value for the $$$
    USA
    the clutch unit is probably slipping due to exponentially increasing air drag fighting against increasing torque from the engine, throwing the code. that theory doesnt hold if you are in overdrive already at the time the code is thrown.
    Sep 2006
    Man, I will be so jealous if you get a '95 Touring!
    My auto fluid has never been changed. 107k. When shifted into Reverse, it has a two-second pause until Reverse engages...i.e., the clutches have wear. Oh well, it shifts smooth.
    I need to get that fluid and filter changed soon.
  1. Thinking of selling my 92 525iT 5spd...
    By stilljester in forum 5 Series BMW
    Last Post: 06-08-2008, 11:55 AM
  2. Thinking about buying a 1997 328i
    By Citizen_insane in forum 3 Series BMW
    Last Post: 04-17-2008, 02:10 PM
  3. New guy thinking about buying 94 540i 6-speed
    By RX7guy in forum 5 Series BMW
    Last Post: 05-01-2006, 10:13 AM
  4. Thinking of buying 1992 525i..need some feedbacks
    By gj1968 in forum 5 Series BMW
    Last Post: 11-24-2005, 07:51 AM
  5. Thinking of buying a E34
    By PdT in forum 5 Series BMW
    Last Post: 10-15-2005, 06:18 PM
