Also a cold engine will wear the cylinder bores and piston rings in a quick hurry!
Originally Posted by
DanDombrowski
Woah guys, don't jump the gun on this one. It could very well be a t-stat, but let me ask this - do you have heat in the cabin? Does the gage move at all?
Theres a connector on the coolant temperature sensor that can get a bit of grease on it and cause the needle not to register, even though everything in the system is working fine. Mine was registering nothing, so I unhooked it and cleaned it, and now it works fine.
Just something to check before you tear into it.
