Originally Posted by
Paul in NZ
ICV very easy to clean.You need some carb cleaner.The Icv is the cylindrical device that branches off the intake boot with a couple of wires on the end.Inside a sleeve needs to spin to allow a cutout to let air through,but this can get "gummed up".My 535 has a very similar lag just off idle but only if you give quite a foot full.As far as gear down changes go dont let it drop down to idle,if you just back off the throttle a bit as the clutch goes in the revs rise of there own accord and match speed almost automatically.You dont need to "blip" the throttle
