Results 1 to 8 of 8
Thread: Best brands of engine Belts?
    Lexington, Kentucky
    Default Best brands of engine Belts?
    What brand of engine ac and accessory belts are best for the M50 engine with the flat sepentine belts? I have been using conti brand but I have heard that Goodyear Gatorback Belts are quieter. TIA
    I am using the conti belts, they come highly recommended everywhere.
    Honolulu
    Default Keep the old ones
    under the spare tire for good luck on the road if you blow a belt.
    ahh the old insurance trick, back in the day we would carry starters and alternaters for that purpose just so they wouldnt go bad.
    Default I don't have great results with the
    gatorbacks, they have diagonal cuts in them to allow them to flex in a tighter radius but those same cuts result in less contact surface on the pulleys makeing them far more likely to squeal from slippage on most cars. I have better results with bando belts on most cars. On bmw's if you want conti's get them from the dealer since the original bmw belts seem to be of different quality than the aftermarket conti belts.
    Lexington, Kentucky
    Interesting. I will check this out as I have the ps/alt belt squealing a bit on the first cold start this morning. I also noted that it squealed a small ampunt when I turned on the seat heater. What does that mean besides more of a load on the alternator and I assume the belt slipping?
    Bando belts eh? Thanks again, Bill
    It is possible your tensioner is worn.
    Default As Tiger said ,it could be tensioner or it
    could just be the belt getting hard and old. I like the bando's because the price is very reasonable and they last a long time, with no squealing. They are stock or oem on toyota,honda, nissan etc and a number of import shops here in the US now carry them. About half the cost of gates, goodyear etc.
  1. Replies: 0
    Last Post: 01-21-2010, 06:19 PM
  2. Choice of brands for E34 cooling systems
    By ktteoh in forum 5 Series BMW
    Last Post: 09-15-2006, 04:59 AM
  3. sway bar links brands?
    By shragon in forum 5 Series BMW
    Last Post: 10-26-2005, 12:02 PM
  4. Haar and Esi brands; ever heard of them?
    Last Post: 09-18-2005, 03:52 AM
  5. Floor Jacks: What are some good brands?
    By Hector in forum 5 Series BMW
    Last Post: 12-02-2004, 11:44 PM
