Results 1 to 3 of 3
Thread: Drivers side headlamp is out but the bulb is OK. LKM?
    Midlothian, Texas
    Default Drivers side headlamp is out but the bulb is OK. LKM?
    swapped bulbs from side to side but the left headlamp is out. Could this be a relay on the LKM or similar?
    Mark Hall
    '95 525iA EAT chipped (just one now )
    '98 528iA
    Default If its lowbeam it could be lkm or it could be fuse, separate fuses for the
    lowbeam on your year... fuses 10 and 11... if its high beam then there's only one circuit coming out the lkm and it splits to 2 fuses also.. so if you have a bad lkm relay both highbeams will go out but you have separate relays in the lkm for the low beams... I'd check the fuses first.
    Quote Originally Posted by Hallmark
    Midlothian, Texas
    Default A separate fuse for each lowbeam? That's wild, but I'll check. Thanks Bill
    Mark Hall
    '98 528iA
  1. Side Marker Bulb Replacement '90 535i
    By hlenoble in forum 5 Series BMW
    Last Post: 03-21-2009, 12:55 PM
  2. Passenger side or drivers side
    Last Post: 11-23-2008, 09:17 PM
  3. 1989 535i (e34) Side Marker Bulb Wattage
    Last Post: 07-27-2006, 08:57 PM
  4. Drivers Side Glovebox
    By Alan_525i in forum 5 Series BMW
    Last Post: 04-11-2006, 03:36 PM
  5. E36 Drivers Side Door
    By civiltp in forum 3 Series BMW
    Last Post: 10-25-2004, 02:29 PM
