the compression number look like the other 7 cylinders. I understand this means the cylinder is the leak...either piston ring or cyl wall...crap!
I wonder what caused this 1 cyl to go bad if the btm-end was rebuilt about 1 year ago?
Any ideas out there and how much repair I'm looking at? Can I have the head pulled and ring replaced on this 1 cyl from the top if thats all that was failing or should I suspect more problems and do more repairs to avoid another similar problem?
