Results 1 to 8 of 8
Thread: New member transmission question
    Dec 2006
    Default New member transmission question
    Well I let my friend drive my car for about 2 minutes and of course something bad happens. He didn't wait the 1 extra second before the car was fully in "reverse" and gave it gas too soon. The car gave a little jolt then fully engaged. Now a few days later the tranny is making a whining/whirring sound. Kinda like rocks are stuck in the tires. It shifts perfectly fine but I'm hearing a lot more road noise than I used to. Torque converter Any suggestions on what it could be and how much it would cost to fix? Last time I let a friend take my car out for a spin. Car is a 94 530ia.
    Dec 2006
    anyone?
    replace the filter and gasket with OEM parts? should take 3.5 quarts for the change. whirring is usually from a wrong size O ring on an aftermarket filter kit sucking air.
    ps you use dextron III fluid.
    Dec 2006
    I had that done last year and it was fine up until this happened. Do you think the "jolt" somehow loosened the oem filter? Is it alright if I continue driving around without fixing it?
    Quote Originally Posted by ByronC
    anything is poss, i doubt it loosened the filter...NO have it checked out, small metal shavings can destroy any trans....better safe than sorry
    a jolt can cause a bunch of stuff to happen. I would put the car in the air and inspect the guibo and centershaft bushings and stuff, then do the trans thing.
    Sep 2005
    Goulburn Australia
    I've recently got a similar sound in reverse. Not a slight reverse but I had to back up about 20 yards and the noise previously described happened. I'm thinking that it is more likely to be the reverse gear rather than the guibo/drive shaft as there is no noise in forward gears. Does this sound right? Oh and the noise came from where the tranny is (under the shifter). Sorry-talking about 4 speed auto.
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
    Sep 2005
    Goulburn Australia
    bump
    Cheers
    Wingman
    NSW, Australia
  1. New forum member with a question
    By Wallace in forum 5 Series BMW
    Last Post: 09-09-2008, 01:59 PM
  2. New member transmission question
    By ByronC in forum 5 Series BMW
    Last Post: 12-30-2006, 02:55 AM
  3. A new member of the clan with a SLS question
    By shrike071 in forum 5 Series BMW
    Last Post: 11-10-2006, 02:49 PM
  4. New member introduction and transmission question
    By Alpinerunner in forum 5 Series BMW
    Last Post: 11-15-2005, 11:04 AM
  5. New Member with a question
    By Hal Dewey in forum 5 Series BMW
    Last Post: 02-22-2005, 03:21 AM
