Results 1 to 10 of 12
Thread: LKM-L Soder Points?
    La Mirada, CA
    Default LKM-L Soder Points?
    So can someone photoshop the point I should soder...ASAP ?
    Thanks
    Honolulu
    Default See those relays?
    http://www.bmwe34.net/e34main/mainte...trical/LKM.htm
    The solder points on the board are where they fail, redo them all.
    La Mirada, CA
    Well E34.net is wrong, per...
    http://www.bimmer.info/forum/showthr...&highlight=lkm
    And I've never sodered so I can't easily spot the failed ones...
    Honolulu
    Default 3 Vs 4 Relays?
    Academic Arguement
    the fix is still the same.
    Finds the larger points on the PC board for the realys and resolder.
    Just gotta use a good rosin core solder and reflow those points.
    Some guys get real anal and desolder, but I've got better things to do...
    NW GA
    Quote Originally Posted by Blitzkrieg Bob
    I think it is a good idea o pick up some solder wick and remove the old solder and apply new.
    1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
    La Mirada, CA
    So should I just place a little bit of soder at the tops of these "caps", (hilighted in red)? The "broken" ones kinda look like the top (cap) of the soder is breaking apart from the base of the soder (only noticable with a maginifying glass)????
    Honolulu
    Default There are also
    Quote Originally Posted by BFEINZIMER
    A few point just above those in red, they correspond to the upper part of the relay and should be done too.
    Looks like you have the idea.
    La Mirada, CA
    Ok but my theory on the "caps" is correct? And for my clarification can you please take the origional picture and hilight ALL the points I should add soder too?
    Thanks man.
    Honolulu
    Default Your on the right track
    Thanks man.
    Your theory on the cap is correct, but it's very hard to see the failure.
    So I resolder all the suspect points, try not to add too much, just reflow a clean joint
    La Mirada, CA
    Ok I see, but liek I said, just add soder to the tip (cap), not around it haha?
  1. M30 lifting points
    Last Post: 10-24-2008, 08:41 PM
  2. jack points...
    By 632 Regal in forum 8 Series BMW
    Last Post: 12-31-2006, 06:13 PM
  3. jacking points
    By broadie777 in forum 5 Series BMW
    Last Post: 07-03-2006, 06:19 PM
  4. Jack Points
    Last Post: 03-02-2006, 10:19 PM
  5. OT need 44 more BS points til I reach a hundred...
    Last Post: 02-22-2005, 11:30 AM
