Thread: OBC display isn't illuminated
    Default OBC display isn't illuminated
    I have a '95 525i sedan. The OBC display next to the radio in the dash no longer illumates. The display in the driver instrument cluster works just fine and the s/r button on the OBC cluster works fine. It's just the OBC display itself doesn't work.
    Is it a regular bulb that I need to replace? Any ideas?
    thanks!
    Honolulu
    Default Check this out
    [http://www.bmwe34.net/e34main/mainte...nel_lights.htm
    Make sure you get the right bulb that's pictured in here, the wrong bulb will burn out real fast.
    Albuquerque, NM
    The correct bulb part number is: BMW part no. 62 11 1 368 299
    Don't let the dealer give you any jazz about part numbers, their ETK still shows the older e28 6V part number and will burn out within a week. The correct 12V 1.2 watt bulb will have a black plastic base.
    More OBC removal info:
    http://www.nmia.com/~dgnrg/page_36.htm
    gale
    Quote Originally Posted by Blitzkrieg Bob
    WOW!! An incredibly quick reply. Thank you SO much! I've been working on a few items this week (repaired non-functioning back-up lights by replacing the switch, fixed the headrests so they go up and down again) and this is one I wanted to finish out.
    allen
    Feb 2005
    Richmond, TX
    Thanks for the responses guys. I've been going through this in the touring. It has been eating bulbs but the dealer is giving me a green base bulb and not the black ones.
    Ticks me off, I've bought 3 sets in the last 3 months.
    1988 M3 - Track rat
    1989 325iC
    1995 530iM
    2000 323iT - UUC BBK, PSS9 Coilovers
    2005 GMC HD Crew
    Albany, NY
    You can buy the correct bulbs from autohausaz.com
  1. Best way to get illuminated rear window switches
    Last Post: 05-11-2008, 12:31 PM
  2. Illuminated Automatic Shift Pattern Need Part #
    By cschneider in forum 5 Series BMW
    Last Post: 09-07-2005, 01:36 PM
  3. Illuminated gearshift selector???
    By EonPeon in forum 5 Series BMW
    Last Post: 07-11-2005, 05:38 AM
  4. Illuminated steering wheel logo
    By simon-york in forum 5 Series BMW
    Last Post: 05-26-2004, 07:16 AM
  5. E34 Illuminated shift knob?
    By jplacson in forum 5 Series BMW
    Last Post: 03-02-2004, 09:36 AM
