Results 1 to 5 of 5
Thread: Opening rear doors if power fails
    Default Opening rear doors if power fails
    Can anyone tell me how I open the rear doors if battery is flat please. I need to get to battery
    Feb 2005
    Grand Marias USA
    I got this from an old post by Shogun.
    First, don't panic - there are options
    Calm down.
    The classic, approved method is this:
    If using remote locking, GET THE KEY.
    Go to the PASSENGERS door... the manual override is definitely present there. This procedure should also work on the driver's door too, but it's your choice and one maybe more difficult than the other.
    Put in the key (duh)
    Lift the handle; hold it up now
    Turn the key to the rear of the car; should hit resistance at about 45 degrees
    Carry on turning to 90 degrees - it will be stiff, it's meant ot be. (Stiff does not mean break the key or lock. Your car may have problems or be different - your call).
    at 90 degrees lock pin should pop up
    return key to vertical
    let handle down
    open door as normal
    Other alternatives are based around at least applying 12v to power locks temporarily. This WILL be required to get into the other doors IF YOU LOCKED UP from the drivers door with the "deadlock" feature... then all the other doors are in deadlock "ignore the pin" mode (and possibly the trunk too).
    Thanks guinness will go and try it.
    Cincinnati, Ohio
    Trunk opens just fine with the key when the car is deadlocked.
    If the car is double locked, there's no way to unlock the rear doors without putting power on the system. Once a front door is open, pop the hood and use the remote positive battery terminal and connect your source's ground to the chassis.
  1. both rear windows not opening
    By gymkata in forum 5 Series BMW
    Last Post: 05-21-2007, 03:27 AM
  2. lost power to windows and doors
    By franks in forum 5 Series BMW
    Last Post: 06-06-2006, 03:58 PM
  3. While we are on the subject of doors not opening
    By F4Phantom in forum 5 Series BMW
    Last Post: 04-10-2006, 01:46 AM
  4. 318i all doors and sunroof power is not working
    By prosssopheap in forum 3 Series BMW
    Last Post: 07-26-2004, 12:33 PM
  5. Vinyl for rear doors...
    By Messerschmitt in forum 5 Series BMW
    Last Post: 04-19-2004, 04:48 PM
