I wonder if the thinking was to try and keep the exhaust manifolds cooler without ventalation...wonder how hot they get both ways...this would be an interesting test
Q:
Front hood venting?
Message: I was looking at the hood(engine cover) on my spare parts car and was thinking it might be intresting to louver a bit of it and see if it reduced the heat of the 750. Being that German engineering has most of this thought out pretty well, I thought to ask if any one has tried any venting and what the result might be. Lovuers were a hot rod must have of the 50's and one of the local guys still has a press?? Dinan added 3 vents on each side for his Turbo install (intecooler air)and they look good. I think.
Answers:
The e32 hood doesn't lend itself to Socal custom
Message: Fast & Furious.
Just remove the rear rubber gasket which seals the hood to the forward support for the IHKA blower & windscreen wiper chamber. As you move, suction from the low pressure zone against the windscreen pulls the heat out the back and up/over the top of the car.
It makes a big difference. Also have your exhaust manifolds/down pipes ceramic coated.
As far as I understand the system and what the German engineers thought of it:
they sealed the system as much as possible, so that no air can escape thru any slots in the hood.
Inside the engine room the air has a kind of pressure from air coming thry the front grill entry, and then the air is pushed to under the car to get out.
If one installs louvers - some are looking very nice, I have seen them on E32 in Germany- the whole system would be not working that good.
Otherwise companies like Alpina or Schnitzer would have installed them too.
here is a link, they make it
This company is specialized in that.
http://www.fredsfab.com/service_categories.php?id=1
Louvers by Canfield
http://www.frontiernet.net/~dlcanfield/
"As far as I understand the system and what the German engineers thought of it:
they sealed the system as much as possible, so that no air can escape thru any slots in the hood."
While I agree with you and this might have been a good idea with 6-cylinder engine, my opinion is that with V-engines, there isn't enough air flow through engine bay. When there's more than 50C (120F) in engine bay at constant 50km/h(30mph), there's definetely something wrong when outside temperature is only 20C (68F). Fortunately around here temperatures over 30C (86F) are very rare and winter is long.
Hoses and plastic parts won't survive that for long and as we know, they don't. "What to do" is the question then and frankly, I don't know. I suspect BMW engineers blocked top venting in order to get more (any?) air flow to exhaust manifolds and gearbox, but this is just a guess.
Large scoop on top of hood might help.
(In/out electronic thermometer used for the science part. )
Tuomas
'89 750il 250k (Brand new LAD bombs (Febi) ordered and paid, chistmas time )
Yes, I'm thinking those engineers were too long on the ganja! Prolly the descendants of the messerschmidt team who came up with the Gigant.
If this system works so well, why are many cars coverting to top mounted venting system. Ford Cobra, M3CSL & ALMS race car, Elise & Exige, and many many others.
The available pull of the airstream over the top of the car is far superior to anything happening underneath. Maybe this thinking is why the B12 5.7 has louver panels in the Carbon hood?
The idea with removing the rear rubber gasket at the rear of the hood seal(partly) is quite interesting.
Plus: Also have your exhaust manifolds/down pipes ceramic coated.
Maybe for some hot climate areas this might be a good idea.
That is a good point, Jeff
so you believe the complete sealing at the hood had the idea behind to cool the exhaust manfild cooler?
So then one should also do the other step when removing the seal at the hood:
We used to coat headders but it was so they lasted longer and looked cool, I never read anywhere that it helped keep them cooler.
Originally Posted by shogun
I also posted that on BB and one comment from a guy who is just installing a Chevy Corvette engine in an E32 is:
quote
I'm not sure of removing the rear seal to allow venting, it's always been my understanding that the area at the base of the windshield was a high pressure area. This should put more air into the engine bay- seems like a good idea. The most benefit would be after you park the car, then the heat has somewhere to go.
when i installed the coated headers on my e30 i don't think they put off any more heat then the manifolds did despite the extra surface area and thinner tubing
yeah i'd tend to agree with him, for one the discontinuity of the bonnet leading into the windshield is likely to cause an area of recirculation (ie turbulence or an eddy) in that area which would mean it'd be high pressure. don't think it'd go into the engine bay but i don't think you'd get much air coming out from the engine bay.Originally Posted by shogun
My friend Reinhard in Germany, the electronic wizzard of E32, develops now for my 750 a system where the aux fan will run after the engine has been switched off till it (engine room) reaches a certain temperature. A temp feeler will be installed in the engine room, and it will switch on the aux fan automatically if the temp exceeds a certain limit.
That will fight the heat in engine room and will be very good for the life of the plastic parts in the V12 engine room.
All will be on a masterboard with all items, this is the layout
http://s71.photobucket.com/albums/i1...d_Lueftung.gif
Presently under test run in Germany.
He also developed this iluminated gear shift system
http://img249.auctions.yahoo.co.jp/u...37815shift.jpg
http://img249.auctions.yahoo.co.jp/u...53p1060747.jpg
http://img249.auctions.yahoo.co.jp/u...29p1060775.jpg
that aux fan delay thing seems to be helpful but don't you think it'll run down the battery especially in a hot day?? while the engine is not running
HID 5000k low 3000k fogs
dynaudio seps. mc intosh amp
Race logic TractionControl
Has been calculated. Most/many of the 750 have a second battery in the trunk which is for aux equipment and to keep the main battery healthy for starting the engine. There is a separation relay between the 2 batteries.don't you think it'll run down the battery especially in a hot day?? while the engine is not running
Usually also there is the parking ventilation which can be operated by timer when engine is off.
Have tested it. The aux fan requires in the low RPM stage 18A, in high RPM 30A. We assume that it needs maybe 10 minutes running of the aux fan after engine has been switched off.
That is quite standard/normal on newer cars with electric fans, that they run for a certain time after the engine has been switched off to cool down the engine/engine room.
