I just installed a clutch(per winfreds archive post) I could not get the bellhousing pump assembly on the tranny case with out the small race and bearing moving out of place.So i went a different route.I put the planetary gear on the b clutch shaft then then small washer race and bearing on the planet gear,put the lipped race on the input shaft then put the shaft on the drive gear.Then the A clutch basket on the input shaft till it snaps all the way back.Then large race and bearing on backside of A clutch basket.Install the bellhousing/pump on to case.spins free,looks right.So Winfred, if you see this let me know if I can do it this way.Seems like the same,just starting on the B clutch with gear and working out to the a clutch basket.My hands could not hold the gear tight enough to keep it all in place when sliding in the bell/pump assembly
