Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Diagnostic reader
    Vorselaar, Antwerp, Belgium
    Default Diagnostic reader
    Hey folks,
    I wish to buy some equipment to read fault codes etc from my car. I have the BMW carsoft 6.5 software, but I still need the cable..
    Anyone know good resources for those cable (and shipping to Europe)?
    I've found this on ebay: http://cgi.benl.ebay.be/Bmw-Diagnost...QQcmdZViewItem
    But maybe I can find it cheaper?
    Thanks!!
    '93 BMW E34 525 TD Touring - 2.5l
    Quote Originally Posted by mitch2k
    Hey folks,
    Thanks!!
    There was someone selling them on www.ebay.com.au for $200 (much cheaper) but I think they might have been Hong Kong based. Try the hk ebay instead maybe- search for completed items also .
    BTW; I'm sure I've seen a USB version with OBDII plugs as well.
    Nov 2004
    Middle England
    Why not just make a cable up as shown in the back of the Carsoft manual like this ?
    You don't really need the connector body that fits the BMW diagnostic socket - you can easily improvise one.
    '90 535iSE Auto (AE+EAT) 123k miles
    '86 F288 69k miles
    '06('89)- PGE 2.0DOHC Turbo
    '03 A160LE 19k miles
    1914 Stellite E2A (no odometer!)
    (+ others I daren't mention here)
    www.pyghtle.com
    Quote Originally Posted by zygoteer
    Stands to reason doesn't it! I thought it needed a breakout box, you certainly did with the older Carsoft versions. That diagram looks like good news... I'd be very careful though, there is 12VDC in that connector. RS232 won't like that one bit. Nick
    Nov 2004
    Middle England
    Quote Originally Posted by genphreak
    The true EIA-RS232 specification is easily +/-12v tolerant, in fact most interface chips that are used are +/-25V tolerant (30V in some cases), however you are correct in that the automotive electrical environment is not computer 'friendly' due to spikes, so for this reason I also use an RS232 opto-isolator adapter to protect my laptop.
    '86 F288 69k miles
    www.pyghtle.com
    Interesting. Does this mean you can put 12V down any of the pins without a problem?
    Nov 2004
    Middle England
    The RS232 protocol is based on a + & - voltage swing to give the required data & handshake signals, so provided it is a 'clean' 12V ... then yes.
    The reason some systems quote lower, and sometimes single-ended, voltages is simply that they are designed to correctly interpret the signal at those levels, from other equipment that have not implemented the full output spec - their input spec will still cope with the higher levels.
    This page is explains most aspects ... http://www.interfacebus.com/Design_Connector_RS232.html , where you will see that the original protocol is tolerant up to +/- 15V, and of course to comply with the spec manufacturers devices will always do better - some marginally, some comfortably.
    The car electrical system is often far from 'clean' though, so I use my opto isolator, where I don't have to worry at all, as it takes +/-60V continuous and is protected up to 2000V spikes/transients.
    '86 F288 69k miles
    www.pyghtle.com
    It looks too easy...
    So it should work with this? http://cgi.ebay.com/ebaymotors/BMW-2...32322362QQrdZ1
    Yes, that might be the same vendor. Now I come to think of it the vendor was Shanghainese, I checked their history out back when I saw it, some time ago. I've NFI it would work, but it looks good. If you do get it, let us know how it goes- but be sure to **check** all the connections against your car's schematics **before plugging it in**, I wouldn't risk my DME or laptop to a Chinese mistake very readily.
    Nashville, TN
    I assume this works with the motronic cars as wel - pre obd1 ?
    Derek A.
    90 535i 5 Speed - Style 5 17"
  1. Anyone in SE WI with a Peake Code Reader?
    By Shankster in forum 5 Series BMW
    Last Post: 04-12-2008, 02:02 AM
  2. Replies: 5
    Last Post: 02-06-2006, 02:56 PM
  3. best source for peake code reader?
    Last Post: 01-24-2006, 02:40 PM
