Results 1 to 5 of 5
Thread: 95 540i Transmission direct swap with 95 530i?
    Apr 2005
    Philadelphia
    Default 95 540i Transmission direct swap with 95 530i?
    I may very well be picking up a 95 540i tranny, part number A5S560Z, which is different from the 95 530i part number A5S310Z. Can these be directly swapped? What would be needed to put the 540 tranny into my 530?
    Both are automatic.
    5HP30 is for 540... 530 use totally different tranny. What is wrong with your tranny?
    USA
    the 540 tranny holds higher torque, has different gearing, and was upgraded in the 3-4 clutch engagement to make it much smoother.
    Apr 2005
    Philadelphia
    Apr 2005
    Philadelphia
    hmmm ok.....
  1. Transmission swap HELP HELP HELP
    By Iwo in forum 5 Series BMW
    Last Post: 10-18-2007, 01:28 PM
  2. Transmission swap help M20 -> M50
    By tgrandahl in forum 5 Series BMW
    Last Post: 06-26-2006, 07:47 PM
  3. Replies: 15
    Last Post: 02-10-2006, 02:47 PM
  4. Replies: 4
    Last Post: 08-04-2004, 09:03 AM
  5. 94 530i engine swap to 4.0 with a stick
    Last Post: 07-13-2004, 12:26 AM
