Results 1 to 7 of 7
Thread: False "Washer Fluid Low" warning
    Aug 2005
    Toronto
    Default False "Washer Fluid Low" warning
    Title says it all. Any ideas? Is this typcically what happens when the sensor fails?
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Honolulu
    Default Dirty connection
    or the sensor has rotated out of position to give false readings.
    there's not much to wear out on these sensors.
    Quote Originally Posted by Jay 535i
    I've had a sensor "fail" on the inside... not just the external connections but it gave a false reading (i.e., chime + warning when the fluid was full). IIRC you could rebuild them but it was a fairly cheap part so I just replaced it.
    Robin
    72 Chevy K10
    01 E39 M5
    Apr 2005
    DC
    same happened to me, the sensor might not be seated in the bottle properly. pull it out and put back in before buying anything.
    And I had a broken cable near the connector to the sensor. These cables are so thin, maybe the are used in mini toy car equipment.
    So first pull the connector, bridge it with a paper clip. If the signal is gone, the wires up to there are o.k.
    Then continue the search.
    Aug 2005
    Toronto
    Thanks!
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    T·O·R·O·N·T·O
    What's with the sudden influx of washer related posts?
    If you end up doing any work like replacing the pump, let me know where you source it
  1. It's the Nagging "Washer Fuild Low" Warning
    By Hector in forum 5 Series BMW
    Last Post: 02-28-2008, 08:59 AM
  2. "High Temp" warning when trying to play CD
    By Koolnkrisp in forum 7 Series BMW
    Last Post: 11-01-2006, 08:36 AM
  3. New warning message "trans program" ? 540ia
    By Brians540ia in forum 5 Series BMW
    Last Post: 09-26-2004, 09:05 PM
  4. procedure to reset "brake linings" warning
    By micjordan in forum 5 Series BMW
    Last Post: 06-20-2004, 09:20 PM
  5. Solutions for false "Washer fluid Low" error?
    By Mitch90535im in forum 5 Series BMW
    Last Post: 05-12-2004, 10:36 PM
