Results 1 to 4 of 4
Thread: check engine stomp test INOP?
    Dec 2006
    Default check engine stomp test INOP?
    Hello there,
    Newbie confused about the check engine codes! I've got a '92 525i e34 M50 USA car and my check engine light comes on intermittently after she warms up. Also hates to idle at first when cold. So I searched and found out about the stomp test. Tried it and can't get the light to blink. I have a car code display and can get that to display info by using the button under the tach. Does this replace the blink codes? or is it just other info? The codes that are displayed are not like the 4 digit codes. What do they mean? I'm totally confused, any help is greatly appreciated.
    Thanks, Dave
    Buy a Peake tool which is much easier and more helpful.
    www.peakeresearch.com
    Dec 2006
    Was looking at those online, Thanks
    Dec 2006
    Default Stomp Test How To
    I had trouble getting mine to flash as well.
    Finally figured it out.
    Turn the key to pos2,(just before cranking position) and IMMEDIATLY depress the pedal ALL THE WAY down and let the pedal ALL THE WAY up five times as fast as you can (before five seconds elapses). This will cause the check engine light to flash a code.
    Good luck,
    M.R.
  1. Blow motor inop/ Climate control system inop
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 04-10-2009, 02:57 PM
  2. Solid check engine light at Stomp Test?
    By Jehu in forum 5 Series BMW
    Last Post: 11-21-2006, 09:05 PM
  3. Stomp test...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 05-13-2006, 02:03 AM
  4. Stomp Test help
    By Springfield1952 in forum 5 Series BMW
    Last Post: 02-21-2006, 07:36 PM
  5. Stomp test..?
    By ilya in forum 5 Series BMW
    Last Post: 03-17-2004, 11:11 PM
