5.5 quarts is what it took (with just a little spillage). Put 2.5 in as Bill suggested, then backed it down off my ramps and up 35 feet to the top of my driveway, where I could straddle the gutter and have the car level with enough room underneath for me to continue to service the transmission. Borrowed a Raytek IR thermometer from work (used to check bearings and switchgear), and when the main pan got to about 95F, started getting the level close to right.Originally Posted by mamilapon
Of course, the filter kit does not include new crush washers, so I've got a slight leak in the fill plug. I had a spare washer for the drain plug (same size as the oil drain plug), but no spare for the fill. Didn't want to overtighten, so I'll pick one up from the dealer Thursday. I'll add just a touch back when I make the swap.
Shifts seem smoother, both up and down. 2nd gear seems quieter than it was (could hear it in the cabin before). Ran across a TSB about lengthening the A/C condensate hoses away from the transmission housing to lower noise; might try that in the near future.
So, the clock is ticking. Last serviced at 92k. Now serviced at 140k. We'll see if it'll go to 170k, and I'll do this again.
